Posted October 8, 200719 yr anyone know or have tested the maw10s to know how high they will run with a relatively flat output and no distortion? i need to get roughly 400-600hz outta em, reason for this is i have come into owning a pro-sound amp, and am looking to create some party speakers.
October 8, 200719 yr I don't think that would be their strength. What drivers are you trying to make them blend with?
October 9, 200719 yr If you're looking for party speakers you will need something that is much more efficient than the MAW-10's. You won't need low bass either - think 80Hz and above with emphasis on ~120-160Hz. That's where most of the excitement is.
October 9, 200719 yr look for some pro audio speakers....i've never done anything with pro audio or seen it done on one of the forums...get us a project log to look at
October 9, 200719 yr oh and about running them at 400hz to 600hz !?!? what did you have planned for below 400? you might want to reconsider your plans slightly
October 9, 200719 yr Author oh and about running them at 400hz to 600hz !?!? what did you have planned for below 400? you might want to reconsider your plans slightlyi think i may have confused you guys, im lookin to use em UP to 400-600hz. i've got roughly 2kw on tap, i heard the mj18's are pretty solid up to about 400hz, as far as the other drivers i was thinking of a compression driver midrange, and a horn tweet. there are a few i have in mind from Partsexpress.com.
October 9, 200719 yr That is really high to run a subwoofer. I agree with mark as well in that you should focus on the 100+ range for the goal you have in mind.
October 9, 200719 yr There are plenty of other woofers that will go up to 1K or so...but the MAW-10 isn't what you're looking for. Something like a B&C, Eminence Alpha or Dayton cast frame would do that, as well as be a lot easier to mate with a horn. Given the right (read: big) enclosure, you'd have plenty of midbass reaching down to the subbass depths with ease.I'd also advise against a horn tweet and compression midrange, might as well get a horn for everything 1K and above.
