October 17, 200717 yr Author Sweet only thing tho they only come in svc 3 ohm?thats gonna hurt me no other coil configs offered?
October 17, 200717 yr No other, single 3 ohm is actually pretty awesome for a 4 ohm stable amplifier, since with impedance rise it will be real close to 4 ohms.
October 17, 200717 yr Author No other, single 3 ohm is actually pretty awesome for a 4 ohm stable amplifier, since with impedance rise it will be real close to 4 ohms.not when your intending to use it for Car audio and you need a 1 ohm load...I would have to get a pair just to get somewhere near that ohm load.. Edited October 17, 200717 yr by Jybfan04
October 17, 200717 yr If you plan on using them in a car, I hope you drive a van or large SUV. They need an enormous amount of airspace sealed, which the only alignment besides IB that I would use one in.
October 17, 200717 yr If you plan on using them in a car, I hope you drive a van or large SUV. They need an enormous amount of airspace sealed, which the only alignment besides IB that I would use one in. Would be neato to see an IB RL-s setup
October 17, 200717 yr I run 4 ohms in the vehicle, no problem if you have an amp that does full power over a wide range of impedances, or have a big enough amp to take the drop
October 17, 200717 yr Author JIMJ how do you have yours setup?What size enclosure and what amp are you using?I did notice that the enclosure requirements are huge sooo may not be able to use this woofer.
October 17, 200717 yr I don't have an RL-s...my comment was just that I have an amp (PG Tantrum 1200.1) that doesn't care whether it's at 2 ohms or 4 ohms, so an SVC 3-ohm driver isn't as much of a problem as long as you know what amps to look at. JL Slash series amps are the same way, along with the newer PG Xenons though I can't comment about the quality of those.
October 17, 200717 yr Author I don't have an RL-s...my comment was just that I have an amp (PG Tantrum 1200.1) that doesn't care whether it's at 2 ohms or 4 ohms, so an SVC 3-ohm driver isn't as much of a problem as long as you know what amps to look at. JL Slash series amps are the same way, along with the newer PG Xenons though I can't comment about the quality of those.Gotcha, care to share a bit more information about your setup ie box size and how many drivers you are using?
October 19, 200717 yr If you plan on using them in a car, I hope you drive a van or large SUV. They need an enormous amount of airspace sealed, which the only alignment besides IB that I would use one in.they dont need huge boxes fyi...unless 5 cubes is big to you? Edited October 19, 200717 yr by TreyE
