Posted October 22, 200719 yr Ive got myself a 1977 Buick Regal...thas one of those metal cars...no plastic...and no type of dampening so yes sound dampening is on my to get list.Im not an all out SPL guy, but not any all out SQ guy... Im more of a "LSQ" guys that many people are...but wont admit it. Due to an awkward trunk...I AM A go with either 1 15 or 2 10s. I want it to sound clean and hit the lows.Boxes im thinking bout ..... two 10s...3 cu ft. tuned to 32hz, 1 15 3-4 cu ft. tuned to 32 hzI dont wanna spend more than 230 for a single woofer or 400 for a pairWOofersFi SSD 15AA Aresnal 15Re SE 10, 15(they are pretty cheap on ebay)Alpine Type-R 10, 15( hear they arent very good on the sq, i heard a pair of 12s...sounded ok to me though)Soundsplinter Ignition Series 10any otherswhats the best...bang for buck, in sq, spl, and lows...
October 22, 200719 yr Author well...what i mean to say...is i want the "ability" to get pretty loud(130-140 dbs) jus for demonstrations purposes(ie showing off to my friends) but not sound like poo when i listen to it at reasonable levels. I wanna hear the words...clearly.
October 22, 200719 yr Try the SSA ICON.A Single 15 would love the ported box size you're able to fit.http://www.soundsolutionsaudio.com/shop/in...p;productId=194
October 22, 200719 yr well...what i mean to say...is i want the "ability" to get pretty loud(130-140 dbs) jus for demonstrations purposes(ie showing off to my friends) but not sound like poo when i listen to it at reasonable levels. I wanna hear the words...clearly.A proper SQ system can do that, easily.The subs are the least important part of that, though.
October 22, 200719 yr Author well...the only problem with me doing a pure sq system is the price...the car is my first car, and this system will be my first system, so funds will be a major issue.
October 22, 200719 yr Not sure what you mean by that. For an SQ system you can use very budget friendly drivers, and even budget friendly installation techniques, but you can't skimp on the time you take when doing the install. It is all install man. Your budget is already way larger than necessary as long as you spend it more wisely than you currently are. Figure out everything except the sub first and go backwards.
October 22, 200719 yr Author I understand what u are saying... Ive got a headunit in mind(pioneer premier). And right now...im planning on running a set of good 6x9s becuase ive got the slots for them in the rear deck, or some 6.5 components in the rear. Only reason is beacuse the front passenger door(its a coupe) has a terrible leakage. I might be able to make some kick pannels but, the area for most kicks is VERY small. For a good budget setup what are some good amps...for my frontstage.
October 22, 200719 yr Rear speakers are not a front stage...you are making this even more confusing. Perhaps taking a step back and giving us all the background would be extremely helpful.
October 22, 200719 yr Author I know what rear speakers are...its a rear fill. But as far as a front stage...that would be hard to do without major modification.
October 22, 200719 yr Then what are you asking with this:"For a good budget setup what are some good amps...for my frontstage."
October 22, 200719 yr My APX 12 plays music just fine. Just turn your subwoofer down and you wont have a problem.
October 23, 200719 yr Author Nevermind that last question...im going to give some numbers i would like to stay under.Headunit($200 and under)Component Set($250 and under)Amps(mono and 2 channel)($300 and under)Sub/subs($250 for single sub setup, $300 for dual sub setup)Sound dampening and materials for enclosure building(???)Installation(i might do it myself)(Free)I wanna end up somewhere around,but would prefer to be under $1000, as this is my first setup in my first car. I am willing to go up to about $1200. I wanna do this right. So let me restate my goals. I want a good sq system. I do understand the basic concept of the sq setup. If you guys could be so helpful to reccomend some pieces in each category that would fit the suggested budget.THanks!
October 23, 200719 yr Just my observations...Lower the sub budget. $100 taken out of that will put $100 more into the front stage and head unit, where it's needed more anyway. Picking a head unit that's capable of active processing will allow you to mix and match drivers, getting a lot more value for your dollar than a pre-built component set would. A used 4-channel amp can be found on Ebay or a forum for not a lot, something like a PG M44 comes to mind...Expect to spend a little over $100 on sound deadening, and cables and wiring aren't free either.
October 23, 200719 yr Author Just my observations...Lower the sub budget. $100 taken out of that will put $100 more into the front stage and head unit, where it's needed more anyway. Picking a head unit that's capable of active processing will allow you to mix and match drivers, getting a lot more value for your dollar than a pre-built component set would. A used 4-channel amp can be found on Ebay or a forum for not a lot, something like a PG M44 comes to mind...Expect to spend a little over $100 on sound deadening, and cables and wiring aren't free either.i would run 2 speakers on the first 2 channels and the 2 tweeters on the 2nd 2 channels correct?what HUs have active processing?
October 23, 200719 yr i would run 2 speakers on the first 2 channels and the 2 tweeters on the 2nd 2 channels correct?Yes. I haven't kept up to date on all the newer models out there...a search around here would get you a lot of info about what people are having good luck with. If you're on a budget, I bet you could find something like an Alpine 9835 that may be a couple years old, but be well under what a new unit might cost you.The amount of value you get out of DIY'ing your front stage vs. buying a pre-built set is just silly, expecially for that kind of budget. There's a lot of compromises that go into a $200 set vs. a $1000 Dynaudio passive set, it's just building to a price point.
October 24, 200719 yr Author Not to lose my focus but this woofer is actually 100 less than my budget and looks pretty nicehttp://www.acoustic-visions.com/~acoustic/...ivers/CSS_SD12/
November 1, 200719 yr Author Well...Im here to update u guys with some new information.I now have a job...which means my budget has increased. Im no longer even considering an SQ setup. Im not going spl...but i wanna be able to get loud(louder than all the guys at skool). My sub/sub amp budget will be about 600. Im looking 2 go, 2 12s sealed, 2 10s ported, or 1 15 ported. IM looking for output, but dialy listnenablity. Good daily pounding. Nothing that sounds like crap. Ive gave my updated budget...now what fits...(Fi, Alpine, Kicker, AA, Sundown, Soundsplinter, ect)Fi BLSS Ignition and Premium SeriesAA ArsenalFi SSDFi QKicker CVXOz Audio Oz V12.3-4SI BMand others...but what route would you guys go to get the most for the money with the Budget listed above. THanks Edited November 1, 200719 yr by kingsham
November 1, 200719 yr i dont get what u mean by ur not even considering a sq setup... sq setup HAVE the ability to play "loud"and drop down low... the whole i want to be louder then all the other kids at school is a silly mentality to have... that is just asking for ur system to get jacked... i run a single 10 in my car... and ppl who ride in my car are so surprised that its only 1 10 they swear it has to be 2 12's or something... its mostly the install... id rather have clear sounding system that stays clear when the volume is up vs a loud fart can... there such a misconception about sq systems... if i were u id deff do more research and really know what u want then start thinking about spending money...
November 1, 200719 yr i'd still concentrate on the front stage if you want a truly phenomenal sounding vehicle....but based on what you are asking, they are all pretty good subs so it's all up to you
November 1, 200719 yr Author Well...im not really tyring to sound like a smart alec...but what do you suggest i do then...
November 2, 200719 yr Author Well...im not worried about sounding pheonominal...1 12inch Fi BL will fit the bill...ported tuned to 32hzbout 3 cu ft boxsome good 6x9s and some comonents in the front...will do me goodit will sound good enough for me...
November 2, 200719 yr well if you don't car about sounding good, then forget running active then and get a cheap passive set, turn the bass way down and the treble way up and crank your gains!i love it when people do that LOL!!
