Posted November 1, 200719 yr has anyone had expeirience with these or the 4000 what are the + and- to them? Are they power hungery compaired to other amps in the same power class?Thanks MC
November 1, 200719 yr I have the opti 6000D, had it benched for me & it put out 3500 rms @ 4 ohms. Was benched on 2 yellow tops, 1 up front & 1 in back. Did very well & was efficient. Edit: After rise during the bench, it did the 3500 rms @ 5.1 ohmsI didn't have the 2 ohm & 1 ohm testings done because we had no subs that could take the power! I am currently using it in my car w/ a 70 amp alternator, stock front battery & Kinetik 2400 in the trunk, I have a constant 14.5V reading at normal listening levels, when I turn it up I have a 13.5V reading, so for me that is not a bad dip at all, but I am not sure what a bad voltage drop is. I assume it's 12.5 or below. Hope that helps! Edited November 1, 200719 yr by thedukey42
November 2, 200719 yr Author I have the opti 6000D, had it benched for me & it put out 3500 rms @ 4 ohms. Was benched on 2 yellow tops, 1 up front & 1 in back. Did very well & was efficient. Edit: After rise during the bench, it did the 3500 rms @ 5.1 ohmswhat kind of voltage was it getting during that bench test I mean that's pretty inpressive if it's that under rated. Do you know how it does on say 10 to 12 volt not that that is what I would have but if the voltage drops then I don't want it to go puff.
November 2, 200719 yr Similar to the SS XXX 10000. I have seen posts on a couple of forums with people getting SLIGHT gains going from the SS10000 to the Opti6000.I owned the Opti4000D and loved it. Ran it on (4) AA Avalanche 15's in my suburban and on a (16) 10" setup for a couple of months. (2) batteries up front and a stock alt. Never had voltage problems.I debated for a long time between the Opti6000D and the IA 40.1s. I was able to pick up (4) 40.1's used for $3000, so I went that route.Brian
November 2, 200719 yr The older ones are higher quality than the new ones. I'd avoid the new ones.Normally I wouldn't disagree with you... But this time, you're off a little.The old Lanzar line was killer. Typical, made-in-america-kick-ass underrated amps. When Lanzar stopped having amps built by Zed the quality went down on the lower lines but the Opti line still stayed a quality line.Not saying they're as good as the older Opti's, just saying.. that they're still way above most amps out there today.
November 2, 200719 yr Author this is the kind of input I was hopeing for. I have a autherized dealer near me and can get one for 1500. Is this a fair price?
November 3, 200719 yr Author I forgot to ask how is lanzar's customer service and warrenties on there amps.
