November 9, 200717 yr Author and to continue......Next step .....vinyl.... Can you tell me how you attached that top panel the were able to push it down and keep it in place without the use of fasteners from the outside? Thanks so very Much. Z
February 6, 200817 yr Author That's some clean work.Thanks Guys for all the replies.....I also do these for GMC/Chevys.....this allows the truck guys to have a nice stealthy setup, but allows room under the rear set for storage....as if the bed was not enough.
December 4, 200816 yr i keep regretting getting the solid center console with the shifter there in my 04 f150...it would make life sooo much easier now to do a console front of the cab to the back of the cab
December 5, 200816 yr Maybe you should do a quick vinyl wrapping thread...I should do this for my '98 K1500 silverado single cab
