Posted November 4, 200719 yr Hello, again. I was just wondering if anybody knew the names to these parts of the car because I need to replace them. The first one is the cover in the back of a sedan (2001 Pontiac Grand Am GT) that has the hole for the seatbelts to come through. Anyone happen to know the name of that? The other one is on the front passenger side. It's the piece most people use to hide their wires.While installing my new system, I broke a clip off of each part so now the pieces wont stay in correctly. I was just wondering if anybody knew the names of these parts so I could purchase new ones. Also, do you think eBay has these? Any help would be greatly appreciated. Sorry if this is confusing. I am about to go to work and just needed to post this before I went. Thanks in advance!
November 8, 200718 yr You will probably have to go to a General Motors dealer. It doesn't have to be a Pontiac dealer just GM. The parts clerk will be able to pull up pictures of the parts you need by your description. It really is not very hard to do. If you have the old parts just take them with you. If you don't take your VIN number it is at the base of the windshield on the driver side.
November 8, 200718 yr I'd start junkyard hunting...seems like a common enough vehicle that a local place might have what you're looking for.
November 8, 200718 yr Yeah, your local junkyard will probably have the parts for much cheaper then a new OEM, if you can live with minor imperfections. Also, study the old part carefully, and have a plan of attack on how to remove it from the donor car without breaking it.
November 14, 200718 yr Man, I wish we had that kinda large pick-n-pull in Hawaii... We only got a little place where the cars are stacked to the sky.
