I have a Kole Audio KX1-5500D putting out 3200 rms at 1 ohm and a kinetic HC1800 battery. how big of alternator do i need?
What exactly are you asking?
chances are you'll need more then just a bigger alt...think more batts and big three as well
ive done the big three and i have 3 kinetic batteries. i just need to know how big of an alternator (amps)
ok well, first off add all the fuses up on your amp(s). try to get an amp close to it. a little under is ok, unless your playing tones or pink you'll never pull max amperage out of it anyways.
