Posted November 10, 200717 yr I'm pleased to announce the new Exodus Audio Shiva-X and Tempest-X are now available. These are brand new XBL 12" and 15" drivers with 27mm Xmax for the incredible price of $165 and $175. Check out the links below for full details and driver applications. Tempest X specs will be up shortly.Check out the Shiva-X hereCheck out the Tempest-X here
November 10, 200717 yr Oh....finally.....wish I had the money now.....hmmm....dad will need sub.....maybe....
November 10, 200717 yr Author do you know what box size sealed and ported do the tempest-x like?Check out the .pdf in the "information library" on the Tempest X page and it will show each of the sealed and ported designs for home audio. If it is for car audio then make changed accordingly.
November 10, 200717 yr What did you end up changing between these and the ones you blew out a few months back?
November 10, 200717 yr What did you end up changing between these and the ones you blew out a few months back?More mass and a softer suspension, primarily.
November 11, 200717 yr do you know what box size sealed and ported do the tempest-x like?Check out the .pdf in the "information library" on the Tempest X page and it will show each of the sealed and ported designs for home audio. If it is for car audio then make changed accordingly.yea it was for car audio.
November 11, 200717 yr Author The specs for the Tempest-X are:Measured with Praxis @ Sea level, 55deg F with drivers broken-in for 8 hours with 25Hz sine wave. Signal level >2V so a relatively high test signal. Tempest-XRe: 3.65 Le: 0.9mHFs: 18.4HzQms: 3.4Qes: 0.6Qts: 0.51Mms: 200.0gCms: .37 mm/NVas: 340LSd: 806 cm^2BL: 11.86I'll be updating the site tomorrow to reflect these numbers.The primary difference is a softer suspension and a different surround. These came in at our original parameters unlike the first batch that we blew out.
November 26, 200717 yr I see that you say the wattage rating on those are a bit conservative...Can it take about 800 watts...I am looking for a setup to have for backup...My sundown saz-1500d puts out about 800 watts @ 2 ohm...
November 27, 200717 yr Author I see that you say the wattage rating on those are a bit conservative...Can it take about 800 watts...I am looking for a setup to have for backup...My sundown saz-1500d puts out about 800 watts @ 2 ohm...I wouldnt put anything over 600 watts to it continuously. I'm not sure if you are thinking about a pair but these are dual 8 ohm drivers so you can only wire as low as 4 ohm with a single driver (2 ohm for a pair).
