Posted November 30, 200718 yr Alright got my SAZ3000 in today, all installed.. went to set gains and couldn't get any voltage out of the amp.. 39volts is what I got with gain all the way up.. aiming for 50 (3000watts). Lowpass was set fine, subsonic wasn't set too high, bass was on the HU. Pretty stumped right now. Also the subs are at 1 ohm.
December 1, 200718 yr What was the voltage coming off of the RCA's at?How about input voltage off of the main power line?
December 1, 200718 yr fosho also are you sure you have a nice ground, and how does your power plant look
December 1, 200718 yr Author Didn't measure voltage of RCAs, voltage at amp was ~12... my kinetik has been sitting for a while so it needs to charge up still but electrical is hc2000 n hc2400 2 runs of 0/1... don't have an alt yet. And amp is grounded directly to the frame.
