Posted December 6, 200717 yr Okay, just brainstorming here...Say I had two D1 subs.I could series wire the coils on each to 2 ohms, then parallel subs to 1 ohm.Or...I could parallel coils to .5 ohms, then series to 1 ohm.But...Could I wire one set of coils in parallel, to .5 ohms, and the other set of coils to 2 ohms, then wire them in series for... .4 ohms? Or is it not good to use different subs...
December 6, 200717 yr Sometimes you just need other people to help your thought process along a little lol
December 6, 200717 yr Author Indeed! I work best when I have others to bounce ideas (or hard objects, for my frustration) off of.
