Posted December 7, 200718 yr Hey If I can get you guys coil specs would I be able to get a shocker sig recone with IA DP soft parts and basket? Edited December 7, 200718 yr by negative3five
December 7, 200718 yr Author Well then how much for a basket the coiling for the bottem of it and a set of terminals?Chad pmed you for the recone... Edited December 7, 200718 yr by negative3five
December 7, 200718 yr Well then how much for a basket the coiling for the bottem of it and a set of terminals?What basket was on the motor to start with? 4 and 12 spokes have a 127mm or 5 inch mounting, where as ours have 135 mm mounting? Check and let me know.Thanks,Nick
December 7, 200718 yr Author Dang I just lined up a cracked 12 spoke up to it and it fits perfect but thier is alot of diff holes on the topplate I could try to figure out what thier spacing is and let you know.
