Posted December 11, 200718 yr 4 - 15" SoundStream T4 subs No. of Drivers = 4 Mounting = Standard Wiring = Parallel Dual voice coils = parallel Fs = 34 Hz Qms = 3.722 Vas = 2.075 cu.ft Xmax = 0.551 in Xmech = 0.827 in Qes = 0.449 Re = 0.417 ohm Z = 0.5 ohm Pe = 1000 watts Qts = 0.401 no = 0.496 % 1-W SPL = 89.1 dB 2.83-V SPL = 97 dB-----------------------------------------Box Properties Name: Type: Vented Box Shape: Prism, square Vb = 15.76 cu.ft Fb = 34.5 Hz F3 = 30.77 Hz Fill = none No. of Vents = 1 Vent shape = rectangle Vent ends = one flush Hv = 34.5 in Wv = 7.75 in Lv = 28.83 in Edited December 11, 200718 yr by Lord Baccus
December 11, 200718 yr Author Good luck with that.Thank you i want to have a boxx that is for Music... ( SQ ) done my way think of it as SQ on Steriodscheck out the FLAT line on that graph... Edited December 11, 200718 yr by Lord Baccus
December 11, 200718 yr Author anyone notice the Fs of the sub is 34.5Hz and the F3 of the Boxx is 34.5 i plan on getting Pap subs to fill the holes soon Edited December 11, 200718 yr by Lord Baccus
December 11, 200718 yr do you like soundstream subs? i almost baught 2 15 T5's...you think that would have been a good investment?
December 11, 200718 yr Author do you like soundstream subs? i almost baught 2 15 T5's...you think that would have been a good investment?depends on what your going to do with them...the Fs of the T5 is like 27Hz ???!!???so it is Strictlly SQ unlike th e T4 with an Fs of 34.5Hz... can go either way...But over all i give the SoundStream an 8 outta 10 for looks and a 10 outta 10 for Sq & Spl... durabale as Hell !!! 2 of my SS subs are over 3yrs old and still Ground Pounding Monsters... they never die if used responsabllyi f-ed 1 up sweeping way below the port freq... but it was an east re-cone...
December 11, 200718 yr low fs and the ability to go really low aren't defining for sq. sq is a combination of much more things. and it's very subjective.
December 11, 200718 yr Author low fs and the ability to go really low aren't defining for sq. sq is a combination of much more things. and it's very subjective.agreed i have been reading and learning about T/sand have noticed that the closer the port freq is to the Fs of the SS T4 15" the better it sounds
December 11, 200718 yr check out the FLAT line on that graph...I can guarantee that once you put it in a vehicle, your real-world response is going to look nothing like that.That's all I have to say about that
December 12, 200718 yr Author check out the FLAT line on that graph...I can guarantee that once you put it in a vehicle, your real-world response is going to look nothing like that.That's all I have to say about that what suggestions do you have ?
December 12, 200718 yr Since you're using BassBox, click on the car tab in the drivers properties and open the car file, then graph it again and you'll get an idea of what Jim is speaking of. That ruler flat line will soon turn into peaks and several of them quite exagerrated.
December 12, 200718 yr Thank you i want to have a boxx that is for Music... ( SQ ) done my way think of it as SQ on SteriodsNow that's funny. Maybe nobody realizes that you're just kidding.....You are kidding aren't you?
December 12, 200718 yr ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha
December 12, 200718 yr Author Thank you i want to have a boxx that is for Music... ( SQ ) done my way think of it as SQ on SteriodsNow that's funny. Maybe nobody realizes that you're just kidding.....You are kidding aren't you? Oh My God FINALLY someone with a sence of HUMOR YES i was Kidding / Joking / Jerking the SQ guys chains...i just do it so i can picture in my mind there faces with the scowlling and looks of hes out of his mind... !!!its so easy to get them all worked up there so serious all the time,they have forgotten to have a lil fun with there systems...my idea of SQ is: Clear enuff to hear for over 4 city blocks....if you ever see LB making a post about SQ its more than likelly a joke thank you for understanding...
December 13, 200718 yr I could see where this was going from the get go. Nothing wrong with a little humor.
December 13, 200718 yr Author I could see where this was going from the get go. Nothing wrong with a little humor. Humor keep me balanced you were the first person to ever get it some of the other guys could use less caffeine in there coffee :)
December 13, 200718 yr I laughed didn't you read my post, but the real funny part is that 6 weeks ago that would have been your definition.
December 13, 200718 yr Author I laughed didn't you read my post, but the real funny part is that 6 weeks ago that would have been your definition.i saw your hahahahahahhaha i was just pokin fun...im a DieHard SPL Freek...but i do like to hear the words and the rest of the music... so you could consider me an SQXtream kind of guy...i have played Bass Guitar for years & years and as i was growing up i noticed the LACK of Bass in the car audio systems i could never hear the BASS in the songs so i Vowed to correct this if i ever got the chance, & it kind of got out of control at this point i addmitt its more OCD than ADHD
December 13, 200718 yr maybe u couldnt hear the bass because u were going deaf?and y does this remind me of happy feet, lmao
December 13, 200718 yr Author maybe u couldnt hear the bass because u were going deaf?and y does this remind me of happy feet, lmao im reffering to Factory systems from 20yrs ago
December 13, 200718 yr Author ooooooooOOOOOohhhhHHHH I thought u meant from the guitarwell now that you mention it ? it might have been a factor
