4 - 15" SoundStream T4 subs
No. of Drivers = 4
Mounting = Standard
Wiring = Parallel
Dual voice coils = parallel
Fs = 34 Hz
Qms = 3.722
Vas = 2.075 cu.ft
Xmax = 0.551 in
Xmech = 0.827 in
Qes = 0.449
Re = 0.417 ohm
Z = 0.5 ohm
Pe = 1000 watts
Qts = 0.401
no = 0.496 %
1-W SPL = 89.1 dB
2.83-V SPL = 97 dB
Box Properties
Name:
Type: Vented Box
Shape: Prism, square
Vb = 15.76 cu.ft
Fb = 34.5 Hz
F3 = 30.77 Hz
Fill = none
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 34.5 in
Wv = 7.75 in
Lv = 28.83 in
:slayer:
Edited by Lord Baccus
  • Replies 105
  • Views 13.3k
Good luck with that.
Thank you i want to have a boxx that is for Music... ( SQ ) done my way :)
think of it as SQ on Steriods
check out the FLAT line on that graph...
anyone notice the Fs of the sub is 34.5Hz
and the F3 of the Boxx is 34.5 :)
i plan on getting Pap subs to fill the holes soon
do you like soundstream subs? i almost baught 2 15 T5's...you think that would have been a good investment?
depends on what your going to do with them...
the Fs of the T5 is like 27Hz ???!!???
so it is Strictlly SQ
unlike th e T4 with an Fs of 34.5Hz... can go either way...
But over all i give the SoundStream an 8 outta 10 for looks
and a 10 outta 10 for Sq & Spl... durabale as Hell !!!
2 of my SS subs are over 3yrs old and still Ground Pounding Monsters... they never die if used responsablly
i f-ed 1 up sweeping way below the port freq... but it was an east re-cone...
low fs and the ability to go really low aren't defining for sq.
sq is a combination of much more things. and it's very subjective.
agreed :)
i have been reading and learning about T/s
and have noticed that the closer the port freq is to the Fs of the SS T4 15" the better it sounds
I can guarantee that once you put it in a vehicle, your real-world response is going to look nothing like that.
That's all I have to say about that :)
what suggestions do you have ?
Since you're using BassBox, click on the car tab in the drivers properties and open the car file, then graph it again and you'll get an idea of what Jim is speaking of. That ruler flat line will soon turn into peaks and several of them quite exagerrated.
Now that's funny. Maybe nobody realizes that you're just kidding.....You are kidding aren't you? :unsure:
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha
Oh My God :) FINALLY someone with a sence of HUMOR :slayer:
YES i was Kidding / Joking / Jerking the SQ guys chains...
i just do it so i can picture in my mind there faces with the scowlling and looks of hes out of his mind... !!!
its so easy to get them all worked up there so serious all the time,
they have forgotten to have a lil fun with there systems...
my idea of SQ is:
Clear enuff to hear for over 4 city blocks....
if you ever see LB making a post about SQ its more than likelly a joke :)
thank you for understanding...
I could see where this was going from the get go. Nothing wrong with a little humor. :lol2:
Humor keep me balanced :)
you were the first person to ever get it :slayer:
some of the other guys could use less caffeine in there coffee :) :) :)
I laughed didn't you read my post, but the real funny part is that 6 weeks ago that would have been your definition.
i saw your hahahahahahhaha :)
i was just pokin fun...
im a DieHard SPL Freek...
but i do like to hear the words and the rest of the music... so you could consider me an SQXtream kind of guy...
i have played Bass Guitar for years & years and as i was growing up i noticed the LACK of Bass in the car audio systems
i could never hear the BASS in the songs so i Vowed to correct this if i ever got the chance, & it kind of got out of control :slayer:
at this point i addmitt its more OCD than ADHD
maybe u couldnt hear the bass because u were going deaf?
and y does this remind me of happy feet, lmao
:nuts:
:nuts:
im reffering to Factory systems from 20yrs ago
ooooooooOOOOOohhhhHHHH :lol2:
I thought u meant from the :slayer: guitar
well now that you mention it ? it might have been a factor :slayer:
