Posted December 12, 200718 yr i want to thank those of you who pointed out the error of the batterys as projectiles.there in a safe place under the amp rack now...back seat has been removed / replaced with a flipp up amp rack boxx placed for fitt
December 12, 200718 yr clean that wiring up man!!!!If ur gonna display ur chit make it clean bro. And secure that amp rack and the batteries in place!!!
December 12, 200718 yr Author you hold the head son im f-ing this Chicken...i did all i could by myself im going to hide the wires... i placed the amps and wired to for placement... the amp rack can flipp up 90degrees so i wanted to make shur i had enuff length on the wires first...it will be finished by the end of the week !!! it'll be so clean back there you would not think its an SPL setup... Edited December 12, 200718 yr by Lord Baccus
December 12, 200718 yr I still don't see anything holding those batteries to the body of the vehicle....
December 12, 200718 yr Yep , still need to at least make something to strap them down my man . In an accident they will make quick work of that plywood
December 12, 200718 yr Author okokko guys the things your seeing in the pics are for PLACEMENT....boxx will be wrapped w/ black to matchmaking sure everything functions & wires have enuff length to open and close the amp rack ...wires WILL BE TUCKEDmaking sure i can reach the Quick connectsetc etc etc...its all i could get done by myself on a weekend...how do you suggest i secure the batterys to the floor ?anyone done this ?
December 12, 200718 yr Well sir, if your committed to not having a back seat. Then I would remove the carpet in that area. Shim, bolt, and glue a couple pieces of mdf in there for a level floor. Build a couple battery boxes, leave and inch or two above the terminals so your wire will fit. Then build your amp rack using the battery boxes, and some stringers between them for support .
December 12, 200718 yr Author I like it.if no one else does.Thank you i did as much as i could by myself...will finish as time allows
