I have been working on my new system ....it is not complete yet
I still have to move the amps to their new location inverted on
the ceiling above the rear seat area..new vinyl on the front and rear
doors and the rear deck/back seat area still need to be done
but this is what I got done so far
this enclosure will take place of the common chamber when it is done....
the tweeter configuration is different...I tried one tweet in the doors..one
on the pillar,both in the pillar,both in the doors exc... and I ended up with
this configuration....
with the use of the wave guides and the way they are placed the imaging
is extreamly good....
Basically, what I'm saying....
Use one tweeter.
I doubt the deck you have has the necessary time alignment functions to make that setup "really" sound good.
I guess the last 23 years of car audio has put my ears out of phase...
seriously...it sounds really good...by far the best sounding components
I have ever heard in a car..regardless of the tweeter configuration
like I said earlier..I tried one set of tweets and both sets many different
ways and this way sounded best
It makes me sad that you haven't heard a real car stereo in 23 years of you being in it.
you got me there.....my last system had a clock radio in each
corner and one on the middle of the dash for the center channel
, the sub box had a pink elephant rotating behind glass
i like the new boxx :)
what is it ported to ?
the old box was a common chamber with 1.6cf3 per sub
plus sub and port dissplacement tunned at 30hz
the new box is 1.60cf3 per sub plus sub and port dissplacement
(seperate chambers) and tunned at 32hz...
so I tried the 32hz tunning for a while...
I liked the tightness and high impact of the
enclosure tunned at 30hz...
so the seperate cavity enclosure is up for grabs...
I am building another seperate chamber tunned at 30hz
I moved the BPX 2200.1 off the floor and put it
on a simple amp rack in front of the enclosure
for now...once the snow goes away and it warms
up I'll strip the interior to build the ceiling amp rack
and dynamat everything
it looks more like a surf board than an amp
install is nice why dont u try 4 cubes (2 cubes each seperate chamber) tuned to 27hz...ur low end will pick up quite a bit
80
this is the largest possible enclosure I can make and still be able
to take it in and out..I had to router the edges of the bottom pannel
on these enclosures to get them to fit into the trunk
it hits really good with the 30hz box...
when I build the box for all 4 woofers I will be tunning it down at about
27hz
nice amp how do you like the amp?. any thoughts on the amp?...
Aloha
x2 what he said :) ^^^^^^
thats a Lot of Tweeter :)
Wow that has to be really clear
Aloha
the Crown amps are true current servo amp
the sound is very tight and detailed
by far the best SQ sub amplification I have owned
Aloha
zomgwtfm8?
It's nothing extremely special. Right now I'm looking at a board almost identical to the one in your amp :)
Aloha
zomgwtfm8?
that might be true,but few amps are as sexy!!!!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
Aloha
zomgwtfm8?
true, true :)
amps both mounted on a rack..
this is where they will stay till I fab up
the inverted rack for the ceiling
  • 2 weeks later...
Use one tweeter.
actually yes it does....I found time today to do some fine tunning...there is a time
alignment adjustment for every RCA out...
I set the automatic time alignment and also did a custom setting
once again with each set on it's own and with both and even played with the
auto eq....
so far I'm really liking this head unit
