Posted December 17, 200718 yr I just got a set of Dynaudio 240GT (MSRP 975$). Before I install them I was would like the best option for imaging. Is there a rule of thumb to tweeter placement (the woofer is going in the stock door location) but the stock Toyota tundra tweeter placement is high in the door, IMO the only place worse is the top of the dash. I don
December 17, 200718 yr Something to consider before you start sweating over where to put the tweeters is Time Alignment and Delay.If you have a good Head unit, place the tweeters anywhere you want, and then measure the delay time to the mid. Use that time to back up the tweeter signal to the mid and you'll be in better shape than if the drivers were right next to each other.
