Posted December 18, 200718 yr go to:about.configand set:ui.key.contentAccess to 41) Type about.config in your browser address window2) In the filter area type ui.key.contentAccess3) Double click on the ui.key.contentAccess and set the value from 5 to 44) Close windowAlt+s should work to add a reply again now.
December 18, 200718 yr Author The only trick was using enough terms in the google search to narrow it down.
