February 19, 200818 yr I just got it today. it's looks great, can't wait to put it in the car. Though I'm still thinking about running it as a second battery and put it close to the amp or maybe use it as my main one up front. Any suggestions?
February 19, 200818 yr Author Adding it as a secont battery as close to your amp as possible is best, Your going to gain in reserve because you still have the main under the hood and because you have the battery next to the amp you should not have to worry as much about voltage drop because of wire length. Its a plus all the way around for the 2nd battery in the back
July 13, 200817 yr Adding it as a secont battery as close to your amp as possible is best, Your going to gain in reserve because you still have the main under the hood and because you have the battery next to the amp you should not have to worry as much about voltage drop because of wire length. Its a plus all the way around for the 2nd battery in the backI guess I missed out, but you said 200 a piece for my 2, and 30 for shipping. LOL
