Posted January 10, 200817 yr cause I dont want to but another rca cable NOW when im just going to get a couple inst. kits later down the line. I have my my 4channel amp running only the fronts right now with a rca cable and no inputs to the rear soooo its ok if I hook up all the wiring to the high input harness and leave out the fronts input?
January 10, 200817 yr So you want to use two channels on the RCA's and two on the High level inputs?Did you RTFM yet? That might tell you if you can or can't since you didn't tell us what amp it is.
January 10, 200817 yr Author oh sht. I get it now, but lucky for me the manual doesnt say anything about the high input. Hooray!Edit--- i comapred it to another of my amps and it says NO. not even going to fiddle with it then. dammmmm I have to buy Y's nowww ughh Edited January 10, 200817 yr by blue fury
