I have a 12" kicker l7 2ohm dvc sub needs 750watts rms i would like to get the kicker 750.1 but i cant wire it to 2ohms to get 750watts so i have to go with something like this. Also are hifonics amps any good? :bull:
# No. OF CHANNELS: 2
# OUTPUT (watts):RMS @ 4 Ohms 220x2
# RMS @ 2 Ohms 380x2
# RMS @ 4 Ohm Mono 760x1
# T.H.D.: 0.02%
# FREQ. RESPONSE (Hz): 10 - 30k
# SIGNAL TO NOISE RATIO: >97dB
# DAMPING FACTOR: >200
# INPUT SENSITVITY: 0.5 - 4.0V
# CROSOVER SLOPES: 12dB
# CROSSOVER FREQUENCY: High-Pass(Hz) 50 - 600
# Low-Pass(Hz) 50 - 150
# SUBWOFFER EQ: 0 - 18dB 0
# SUBWOOFER EQ FREQ. (Hz) : 40 - 120
# DIMENSIONS (INCHES): 9.5x2.5x20.0
# Fully regulated MOSFET power supplies
# PWM circuitry
# Tri-guard amplifier protection
# IDI (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
# Platinum RCA inputs and outputs
# Line Outputs
# Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
# Continuously variable high and low-pass crossovers
# Variable subwoofer equalizer
# Phase inversion switch (0 - 180)
# OEM floating ground input
# Platinum 4-gauge power connectors
# Tri-mode operation
# Optional Remote Bass Control (EGA-RM)
# 2-YEAR WARRANTY
Do these amps have alot of problems?
Edited by KiCk'Z L7
You need either 4 ohms or 1 ohm... soooo I'd say start looking for a one channel amp that can hit the full spectrum of ohm loads rather than a two channel amp that only does the power you need at 4 ohms bridged.
