Posted January 18, 200818 yr how much does an RE SX 18" weigh ???web site says 27lbs ???that cant be right ? can it
January 18, 200818 yr i believe so, i mean they use the same basket for that whole line.I could pick it up wt no problems..
January 18, 200818 yr my 15s i think are in the 27-29 ish range... its only a little bigger basket and cone weight.
January 19, 200818 yr when i shipped mine out it was 32 pounds shipping weight. why do you need a sub to weight more?? if you think weight is an indicator of performance go pick up a power acoustic mofo.
January 19, 200818 yr My 2 SX 15's weigh 28.9lbs a piece. Identical.... I thought the 18 was like 31lbs on woofersetc.com....just with a tad bit heavier cone weight with a bigger basket.Website says 27lbs for the SX 15's I have and it's almost on the nose.
January 19, 200818 yr Author i just assumed the RE line would be heaver as i helped a friend install a RE 12" xxx and that thing weighed over 50lbsi was stunned that the SX has such a low motor weight... and claiming 1000rms
January 19, 200818 yr i just assumed the RE line would be heaver as i helped a friend install a RE 12" xxx and that thing weighed over 50lbsi was stunned that the SX has such a low motor weight... and claiming 1000rmsMOTOR WEIGHT DOES NOT INDICATE POWER HANDLING!!!!!!
January 19, 200818 yr The XXX also cost triple what the SX does... I beleive the SX is more comfortable with around 1500 RMS anyhow
January 21, 200818 yr Author well i guees the egg is on my face thats what i get for assumming Edited January 21, 200818 yr by Lord Baccus
January 30, 200817 yr how much does an RE SX 18" weigh ???web site says 27lbs ???that cant be right ? can it anything below 50 lbs for an 18" woofer is probably bullspit no offense to anyone...
February 22, 200817 yr how much does an RE SX 18" weigh ???web site says 27lbs ???that cant be right ? can it anything below 50 lbs for an 18" woofer is probably bullspit no offense to anyone...bringing this one back from the dead, they use the same motor and baskets are very light. so unless you have a 20 pound basket the re sx 18 will still weigh about the same as the 12 or even the 10.
February 23, 200817 yr When I first bought my SX18 I was really skeptical with the weight of the woofer as well. But she's been taking a lot of power since then.. It currently resides in my living room taking care of the lows.
