Posted January 22, 200817 yr Ok so heres the deal. I have one of these and i just ordered a 15 Fi BTL dual 1, everythin except the cooling. My question is if i were to get a second sub again dual 1 and wire them both to 2 ohm that would be one ohm at the amp right? Also if i were to strap another amp it would still equal one ohm at both amps right?
January 22, 200817 yr You can get a 1 ohm final load from 2 DVC1 subs.If you strap 2 amps to a 1 ohm load, each amp would see a 1/2 ohm load
January 27, 200817 yr Author You can get a 1 ohm final load from 2 DVC1 subs.If you strap 2 amps to a 1 ohm load, each amp would see a 1/2 ohm loadThanks for the answer..I have another question though. I sold my powerbass asa2000.1. My question is since i have a dual one woofer that can take a pounding...can i buy two hifonics brutus 1606 and run one to each voice coil @ 1ohm of course?
