Posted January 31, 200818 yr Are these amps much good, for the price? Does anyone know if the 1Kw class D puts out actual and how about strapped? The guts don't look that bad inside, and I don't think they sold these at walmart.
February 3, 200817 yr Author Nobody has run these gems on subs??? Actually they have all Fairchild transistors in them, pretty good stuff. Not so good with vibration without some mods however.
February 3, 200817 yr I believe RF made these.I was going to get some a while back on ebay, they go for pretty cheap.The only person I know of who runs/ran a LA amp was jmanpc on ca.com
February 3, 200817 yr I have never ran a strike series I use to run a LA Storm X1.2000.1. Did alright, maybe a little overrated. And rockford fosgate doesn't make the LA amps.
February 3, 200817 yr I have never ran a strike series I use to run a LA Storm X1.2000.1. Did alright, maybe a little overrated. And rockford fosgate doesn't make the LA amps.The X1.2000.1 is built a little on the cheap side. Decent amp, but on the cheap side.And it does rated power
February 3, 200817 yr Author I was told RF bought the company but has yet to make the amps. They have some good components in them compared to other cheap Asian amps, but they are slapped together about average I saw one broken from vibration. I can get one cheap thought it might work for a spare. Have an alpine 500wrms I plan on using that I think will be enough but you never know. Just daily driver SQ with a little thunder now and then...and likely will run IB subs yet that don't take much, the 4 12s or maybe pair of 15s. My 420wrms I have now is not quite enough for these 12s but thinking of changing them out to something lighter or 15s as it is loud enough. Of course more power and SQ go together even if it is dialed down.I can get 3 of the 1kw class d, they can be strapped for 2kw at 2 ohm. But have no use for that much sub, what I have is really too much.....yeah that is just about right though.
