Posted January 31, 200818 yr This is my first post really, just lookin around for an upfiring, ported design for two 12" woofers, preferably tuned to 32Hz....please and thank you for any feedback on this. Edited January 31, 200818 yr by DeepSubBoy
January 31, 200818 yr What drivers are you using ? It will make suggestions a lot easier . I have a three ring binder stuffed full of enclosure designs
February 25, 200818 yr Author Vehicle would help too.derr I left that part out Yeah that would help you will prbably find me strange for this, but i will have the box in my room. a requirement i left out was it has to be able to fit through a door way. i am using the visonik drivers from this box: http://www.millionbuy.com/visvb212pkw.htmlsame amp too, if that matters
February 25, 200818 yr OK... so it has to fit through a door with no dimensions. Cool. That should be easy.
February 27, 200818 yr Author OK... so it has to fit through a door with no dimensions. Cool. That should be easy.i am really confused as to whether that was sarcasm or not, so lets just say itz a regular 7 ft door way
February 27, 200818 yr OK... so it has to fit through a door with no dimensions. Cool. That should be easy.i am really confused as to whether that was sarcasm or not, so lets just say itz a regular 7 ft door wayGo measure your door.
February 28, 200818 yr Author 32Hz is way, way too high to be used in a room, IMO...alright....i was afraid to try it because it would b massive, but i would love to do 24Hz
