March 1, 200818 yr Do some research or just read the whole thread. That question has been asked a thousand times already.
March 8, 200818 yr If this was mentioned, I apologize. I read the whole thread but I missed it if it was there...The 1 cube that is recommended for this woofer, is that before or after displacement?
March 8, 200818 yr After, you can rest assured all enclosure recommendations are net volumes.And for clarification, all Mags will be Dual 2 ohm only and 12"D.
March 8, 200818 yr Author I suppose I should start another thread and sticky it and lock it with the information on the new Mag's. I think the problem is there are too many threads about the Mag and people hop in and don't read the other threads. Good, consider it done. Now, wasn't that a good talk? I think so.
March 8, 200818 yr Damn, that's a small box. I was pretty set on getting a pair of Q's. Can anyone that is NOT biased convince me that I should get Mag's instead... but that's if the new ones will be out in the very near future....
March 8, 200818 yr I don't know how anyone can convince you other than based on SI's reputation with previous products. The new driver is not out yet, so nobody has experience with it or can do comparisons.
March 11, 200818 yr A general question about the new Mag...(I may have missed this earlier though)The recommended 1 cu. ft. (or 0.8 cu. ft. with polyfill) is that before or after driver displacement?
March 11, 200818 yr Author PS: It's in the new thread I stickied. http://www.soundsolutionsaudio.com/forum/i...showtopic=15422
March 11, 200818 yr PS: It's in the new thread I stickied. http://www.soundsolutionsaudio.com/forum/i...showtopic=15422Great thanks Nick!
March 14, 200818 yr would u guys recommend a smaller enclosure than 1.5 cubes for ported? if so, would there be a audible difference?
March 15, 200818 yr Stupid question but since the mag and the bm use the same Xbl^2 motor. Do they have the same efficiency? or is one more efficient than another...
March 15, 200818 yr They don't use the same motor. They use the same motor topology (XBL^2), but the motors are different. The motor and all moving parts, along with enclosure will be the determining factor for efficiency, not just the motor.
March 16, 200818 yr Author The BM is technically more efficient from the 1w/1m standpoint, but not by much. The BM and the Mag are both inefficient on the 1w/1m front, but they are efficient when it comes to output (read the paper on subwoofer efficiency on our technical web page). The new Mag and new BM are both a LOT more efficient than the previous models regarding output from small sealed boxes.
March 17, 200818 yr Ohh ok. I'm asking because the BM is only going to be dual 4 and the mag only dual 2. Am planning a 1 sub system and was wondering which to choose: - new BM with 400rms sealed (0.5 to 1.0cuft) or - new Mag with 650rms sealed (1.0cuft)My system consist of: CD7000Focal 165K3P upfront bi-amped (TN52 replaced by Brax Matrix 1.1)Milbert Bam 230ab for Mids and TweetsAudison LRx3.1k for Midbasses and Subs Wiring: Comps - Totem Acoustics Tress // Subs - Van Den Hul The Magnum Hybrid // Comps RCAs - Van Den Hul The Integration // Subs RCA - Tara Labs RSC Sub
