Posted February 12, 200818 yr has anyone bench tested on of these I have heard on other boards that they compair in output power to a DD Z1 even though they are rated @ 3600 is this true? thanks
February 13, 200818 yr Author They're under rated quite a bit that's what I've heard do you know what they bench on a 12 volt set up
February 13, 200818 yr I'm working on building a nice load to be able to test them out...BUT, as far as the guts look, I'd say somewhere around 5k. On the inside it looks a lot like the AB 500.1.
February 13, 200818 yr Author I'm working on building a nice load to be able to test them out...BUT, as far as the guts look, I'd say somewhere around 5k. On the inside it looks a lot like the AB 500.1.cool come on taxes
February 13, 200818 yr What are your plans for it/them ? You should grab some from ScottieJ, on ca.com or keep your eye out on the spl forums, maybe you can score one even cheaper than Scottie's
February 13, 200818 yr I'd rather have one over a Z1 no matter what the power output was compared to it
February 13, 200818 yr My new subs will be dual 1 ohm - 1 sub per 40.1 @ 0.5 ohms. Going by my past 3 sub setups in the wall, I am guessing around 0.8-0.9 ohms with impedance rise playing music. Can't wait to see how that works out
February 13, 200818 yr Author What are your plans for it/them ? You should grab some from ScottieJ, on ca.com or keep your eye out on the spl forums, maybe you can score one even cheaper than Scottie's 2 HDc315 for street beat in a bug wired to 1ohm hope to get a 150db will post pics when done. also can I get a link to ScottieJ's ad couldn't find it. thanks
February 14, 200818 yr Author http://www.caraudio.com/forum/showthread.p...699&page=16hey thanks for the link I got intouch with him and hopefully he still has one in 2 weeks
February 16, 200818 yr according to scottie johnson they do3600 @ 12.8V4400-4800 @ 14.4Vand7500-8000 @ 17Vall value are at 1 ohm. only real testing i have seen thus far.
February 17, 200818 yr according to scottie johnson they do3600 @ 12.8V4400-4800 @ 14.4Vand7500-8000 @ 17Vall value are at 1 ohm. only real testing i have seen thus far.I would say these numbers are about as close your gonna get to real output.
February 20, 200818 yr they are pretty big: 10.08 W x 25.6 L x 2.71 HBrian Edited February 20, 200818 yr by BKOLFO4
February 20, 200818 yr Author they are pretty big: 10.08 W x 25.6 L x 2.71 HBriangood will leave me about 10 inches
