Posted February 12, 200817 yr i did a 149.0db Sunday with 1 sub ported to 36Hzgoing to build an SPL box for it now and get over the 150.0db mark with a singel sub Jacob i am out of Flyers need more as everyone is wanting info SounsStream 15"XxX Edited February 12, 200817 yr by Lord Baccus
February 12, 200817 yr As soon as i seen what sub you were using... no wonder, hehe.Did you use 2 1500ds? If you did that's a great score for the power.Hey, take some wrap and wrap your box like you do your amps for your SPL box.
February 12, 200817 yr Author @ 2000rpm the voltage is 14.42vwhen the amps hitt it dropps too 13.72v... + or _ a lil
February 12, 200817 yr @ 2000rpm the voltage is 14.42vwhen the amps hitt it dropps too 13.72v... + or _ a lilSuck. Too bad you don't have a 16v system. That'd increase the 1500D's output quite a bit.
February 12, 200817 yr Author @ 2000rpm the voltage is 14.42vwhen the amps hitt it dropps too 13.72v... + or _ a lilSuck. Too bad you don't have a 16v system. That'd increase the 1500D's output quite a bit.that would also move me into another class...but im getting currious to see how they would preform with 16vi have an 8v & a 6v battery that rest @ 14.97v.just need to get off my Lazzy @ss and fixx a battery boxx to catch the over flow.. they seep whan they get hot ?!? Edited February 12, 200817 yr by Lord Baccus
February 12, 200817 yr Author WOW really nice number for 1 sub!! that # can deffinitely go upit is going to im shooting for 155db you have to have a goal
February 12, 200817 yr wow that ill be nice, im shooting for a 150 with 1 15" too but it ill be a lot harder for me since i have a minivan lol
February 13, 200817 yr @ 2000rpm the voltage is 14.42vwhen the amps hitt it dropps too 13.72v... + or _ a lilSuck. Too bad you don't have a 16v system. That'd increase the 1500D's output quite a bit.that would also move me into another class...but im getting currious to see how they would preform with 16vi have an 8v & a 6v battery that rest @ 14.97v.just need to get off my Lazzy @ss and fixx a battery boxx to catch the over flow.. they seep whan they get hot ?!?I'm no rocket scientist by any means, but you've got a problem. If you want more voltage, throw those two junkers away and buy a single good battery or two that match.
February 14, 200817 yr Author i did that so i would not have to go into the extream class,,, my batterys rest @ a hair under 15v keeps me in Pro Class
February 16, 200817 yr Nice #'s.The highest I got w/ my 1 9515 was 149.8dB on a 20.1 at .35ohm dcr. Voltage was dropping to ~10v Good luck on that 150!
February 16, 200817 yr Author Nice #'s.The highest I got w/ my 1 9515 was 149.8dB on a 20.1 at .35ohm dcr. Voltage was dropping to ~10v Good luck on that 150!WHAT WERE YOU PORTED TOO ???i am going to build a 3cf ported too 52Hzi did the 149.0db in a 6cf @ 36Hz
February 19, 200817 yr Nice #'s.The highest I got w/ my 1 9515 was 149.8dB on a 20.1 at .35ohm dcr. Voltage was dropping to ~10v Good luck on that 150!WHAT WERE YOU PORTED TOO ???i am going to build a 3cf ported too 52Hzi did the 149.0db in a 6cf @ 36Hz I peaked at 46hz w/ that box.My truck does not like the lows much.I'm looking into getting a vehicle to use for comp only though.Found a Sanoma I may try out.
