Posted February 13, 200818 yr Amp: 1200x1 at 2 ohmsSubs: 2 DVC 4 ohms subs wired to 1 ohmI'm using a DMM to set the gains and my guestion is: Do I set the gains using the formula volts = SqRt of(1200 x 1) or volts = Sq Rt of (1200 x 2)The difference is 34.6 volts for the 1200 watts at 1 ohm and 48.9 volts for the 1200 watts at 2 ohms
February 13, 200818 yr Author is the amp 1 ohm stable?no but my dealer and a guy from pheonix gold said its ok
February 13, 200818 yr What you ideally need is what power that amp produces at 1 ohm.From my past experience reading posts, it doesn't produce much more than it makes at 2 ohms. Probably about 200 more watts.
February 13, 200818 yr Author the amp is a Pheonix Gold RSd 1200.1 info Edited February 13, 200818 yr by lakaiguy
February 13, 200818 yr Author the amp does 1200 at 2 ohmsi need it to do 1200 at 1 ohmit does it just fine but yes wildly inefficienti'm just curious what voltage reading i should start with 34.6 or 48.9 Edited February 13, 200818 yr by lakaiguy
