Posted February 14, 200818 yr seen there was a guy with a blazer that had one and i got a blazer how bad does it draw current?how big of alt you got and batteries?
February 14, 200818 yr Nice amp Installed one on a system with a 120A alt and 3 400Ah batteries (not your regular batteries). I think you could go with a bigger alt and 2 extra batteries but it depends on what you want to do with it, ie compere or use it daily.I tested it against some other amps but let me look for the numbers
February 14, 200818 yr Sorry, I didn't measure current draw, but you can estimate it...the amp is about 75% efficient. Let's assume it has an output of 5kw. This means it will draw around 6.5kw at full power. Divide it by your voltage and there you have your current draw.
February 17, 200818 yr Author well i got a 180 amp alt and a kinetik 1400 im running it at 4 ohms im either gonna do an 800 under the hood and 3 1400's in the back or trying to figure out a way to put the 1400 under the hood and 2 2400's in the back
February 17, 200818 yr I got a 250a alt wt a kinetic 2400 and odyssey batt...haven't had any problemsthe guy i bought it off of had a stock alt and a kinetik batt, but i dont think he had it below 4ohms
February 18, 200818 yr Author do you have pics of your install,wheres your amp mounted?what numbers you posting up?
