Posted February 15, 200818 yr i need fairly reasonable amp(s) to power these two drivers, also how many yellow tops would be good for this application if im using a 200 amp alt? if its not two much trouble can someone break the channel thing down for me as far as when you would use what type of amp..
February 16, 200818 yr Normally you used 2 and 4 channels amps for your front drivers, not your subs. Stick to monoblocks for those.
February 16, 200818 yr Nothing particularly wrong with using a bridged 2-channel for subs, but most of the time it's not for very power-hungry applications.Definitely not for one BTL, never mind two
February 16, 200818 yr Nice 4 channel would be the big boy from RockfordAnd after you sell one kidney, you can have one too!
February 16, 200818 yr sundown saz 3000d will surly show you the road to bass. why tha BTLs? mono block is a one output made for subs.2 channel is for powering left and right. say if you wanted a stereo sub system. or you can bridge a 2 channel for a mono output if the amp is able to.4 channel is more for your inside speakers, you can set it up many ways, left right and front and rear....... or a active system, witch is all front, 2 channels for say mids, and 2 channels for highs, i donno if i relayed it right. but thats the way i have allways understood it but i dont know much.
February 17, 200818 yr Author Yea i pried that saz 3000-D annnndddd...i think imma leave my arms legs an left nut where they are...and not sell them...and look at something more like the hifonics amps...
February 17, 200818 yr Yea i pried that saz 3000-D annnndddd...i think imma leave my arms legs an left nut where they are...and not sell them...and look at something more like the hifonics amps...well fi's are not 1 ohm.. there 0.70 ohms... a hifonics goliath wont go under 1ohm. so you will need to look into TWO hifonics amps.
February 17, 200818 yr And I wouldn't expect nearly the results, the Hifonics are a budget amp...and that is being nice.
February 17, 200818 yr Author And I wouldn't expect nearly the results, the Hifonics are a budget amp...and that is being nice. ok im just gunna ask...what is a good amp, that isnt gunna drain my college savings account lol...
February 17, 200818 yr I'd look into mostly used things, but let's face it, 4kW is not really "budget" territory.
February 17, 200818 yr sundown saz 3000d will surly show you the road to bass. why THE BTLs? mono block is a one output made for subs.2 channel is for powering left and right. say if you wanted a stereo sub system. or you can bridge a 2 channel for a mono output if the amp is able to.4 channel is more for your inside speakers, you can set it up many ways, left right and front and rear....... or a active system, witch is all front, 2 channels for say mids, and 2 channels for highs, i donno if i relayed it right. but thats the way i have allways understood it but i dont know much.the way I see it... a watt equals a watt. As long as the amp can power a speaker doesn't matter what speaker it is - tweeter, mid, etc
February 17, 200818 yr sundown saz 3000d will surly show you the road to bass. why tha BTLs? mono block is a one output made for subs.2 channel is for powering left and right. say if you wanted a stereo sub system. or you can bridge a 2 channel for a mono output if the amp is able to.4 channel is more for your inside speakers, you can set it up many ways, left right and front and rear....... or a active system, witch is all front, 2 channels for say mids, and 2 channels for highs, i donno if i relayed it right. but thats the way i have allways understood it but i dont know much.the way I see it... a watt equals a watt. As long as the amp can power a speaker doesn't matter what speaker it is - tweeter, mid, etci dont seee it that way at all
February 17, 200818 yr the way I see it... a watt equals a watt. As long as the amp can power a speaker doesn't matter what speaker it is - tweeter, mid, etcThis is very true, and a lot of people hear will probably agree with you, but for this application the user needs a lot of watts. It doesn't really matter if its a 2 channel or 4 channel or mono-block as long as it can put the neccessary power to the speaker. In this case though a good mono block amplifier is needed because no other kind of amp is as cost effective. Other amplifiers, such as Hifonics, you have to be weary as to if they even put out the power that they are rated at or if they can stand to be played at such a low ohm for extended periods of time with out breaking down or over heatingWith those subwoofers I would not look anywhere other than at 3000-D. You could also look at the Rockford T40001bd, but I think that would be even more out of your price range. Realize with the power you need to be putting out there will be a lot of wiring and atleast one extra battery more than likely.
February 17, 200818 yr T40001bd only plays as low as 2 ohms is that rightThere site says it is rated at 4000x1@1ohm
February 18, 200818 yr I just wish companies made 4 channels that did a solid 500 watts a channel lol...I'd love that
February 18, 200818 yr Author sounds like im making a big step in this project...which may take some time...i guess i didnt realize how big a deal a 3kw system is...i know imma end up with 'budget' amps until i can afford the SAZ...anyone got a used one lying around? =D lol
February 18, 200818 yr Author How are lanzar amps? the MXA282 4000 x 2...definitely a budgtet amp...but will i be replacing it every other weekend?
February 18, 200818 yr How are lanzar amps? the MXA282 4000 x 2...definitely a budgtet amp...but will i be replacing it every other weekend?Piece of sh!t amp....puts out like 600 watts maybe.
February 18, 200818 yr Author thanks for the suggestion bigjon...but i dont think the t15kW puts out enough power HAHA...and i guess the lanzar idea is out the window...how can they claim its ratings to be so much higher then they are?
