Posted February 21, 200818 yr For as long as I've been in car audio (not long), sub break-in has been a topic I haven't had a clear answer in. My question is, what T/S parameters will change once the woofer has had adequate break-in time, that is if any change (this would make me think its a myth). I've heard that the Fs of the driver lowers because the spider(s) loosen up, and if that is true would it also affect Qms of the driver? The reason I ask this question is regarding the Maw 15, would the break-in of this woofer affect which enclosure to stick it in? I have been modeling this woofer in WinISD and the woofer looks optimal with a 32hz tuning instead of a 30hz tuning you guys suggest(this is with 3 cubes). Sorry for this very long, and probably useless question.Thank you,Larson
February 21, 200818 yr Yup. Just as Acid said, drivers are exercised before parameters are measured. So what is posted gives you the closest numbers to "real world" as you can get.Best,Mark
