Okay 2 DEI Viper Dual 4 ohm 12" subs ported box, tuned to 28 htz. And neither on the back seat nor in the trunk with the seat folded down, I still can't get over a 141. I got a 140.3 the 1st time with shittier subs, and a sealed box..............and running the amp only @ 2 ohms not 1 like today...........But that Was in a Mountaineer............Anyways after I got 2 CRX style boxes from Kurt I was able to do a 144.4 from the back seat. Thew boxes wouldn't fit in the trunk which rots. I am going to Competiton this Sunday in Rochester and then again Sept. 11th in Limestone, NY. Hopefully I can place in Advanced NW this weekend and place in the 1-306 class later on........I can only hope and pray to do well.
J
tuned at 28???
tune it up a lil higher and ur sure to get a better score, i think :ugh:
Yeah, A little higher doing would do better. If you want some SQ I would tune to 40 but if you are not concerned about SQ, tune to 47-48.
shoot for 2-12s in a trunck thats not a bad score.
was it on the new termlab mic.
and yeah try tuneing a little higher, i would go 36-38hz w/60-80sqin of port area...
jamie
jamie
It was on the old termlab..............like I said got new boxes and got a 144.4 on track 48 from IASCA's test tones CD. I believe he box was for a DD 3512 or 9512.............Either way think for a local comp in Advanced No Wall its worth shit???
J
on the old termlab with two crossfire BMF 12's, 1000 watts, 4 cubes ported to 50 hz, i got 145 out of my trunk. somewhat similar setups, you just need to tune higher. that will make quite a difference. I think I got second out of 6-7 competitors in my class, too, so it's not that bad. think i only lost by like .2 db or something, too. he even had a hatch.
About 8 more db or so would of taken 2nd for me........ Between McVay :whipitgood: and this cat with an MT 15" I was toast neways. But what car did u have?? Keep in mind this is in an Intrepid. :poop:
J :boxin:
