Posted February 29, 200817 yr my tweeters are tyring to pump out way to many vocalswhats the easiest way to cut some lower frequencies?I'm hoping its as easy as putting some capacitors inline with the tweeter
February 29, 200817 yr The easiest way would be to simply adjust the head unit or crossover if you had one
February 29, 200817 yr Author ok i'm a dumbyi found the "bass blockers" on crutchfieldthey have 1.2 kHz, 2.8 kHz and 5.6k HzI'm pretty sure the 1.2 kHz is too lowCrutchfield link
February 29, 200817 yr Aren't you already using crossovers, at least passives?All the passives I've seen have been well above the midrange...
March 1, 200817 yr Author Aren't you already using crossovers, at least passives?All the passives I've seen have been well above the midrange...nope just the HU xovers
March 1, 200817 yr Search on ebay to see if you can just find a cheap set of component crossovers that someone isn't using. Like from a Pioneer or MTX etc cheap component set.If you're on a budget and you just want a better blend out of stock speakers, this is the way to go. I've done it in a stock Civic with great success.
March 4, 200817 yr I have apair of passive kicker xovers... 4.5 khz @ 12dB/octave... look & work like new.PM me if you want them.
March 4, 200817 yr Aren't you already using crossovers, at least passives?All the passives I've seen have been well above the midrange...nope just the HU xoversThen adjust the H/U crossovers up in frequency.
