Posted March 8, 200818 yr I have 2 15" lanzar subs hooked up to a 1400 watt lanzar amp.. how do you wire the amp down to .5 ohms so it will be max porformace 1300 watts??
March 9, 200818 yr Welcome to the site!We will need some information...What model is the amp?What model are the subs?What voice coil configuration do they have?Are you sure your amp is stable down to .5 ohmsTruthfully, my post originally said, "If you have to ask, then you shouldn't do it." But since you were new to the site I figured you might be new to the whole learning curve.Some general facts....5 ohm is usually a very hot, unstable environment. Very few amplifiers are capable of running that low and none are covered by any manufacturers warranty when being ran that low.The only way to run two subs at .5 ohms is to have 2 2ohm DVC (Dual Voice Coil) Subwoofers
