March 14, 200818 yr Push?Do you mean power?Yes, it will. That is, if the amp actually works./sarcasm That should do a pretty decent job on them.
March 14, 200818 yr Dont plan on dropping below 1 ohm on the amp..... A friend of mine has one and has popped it twice when dropping below 1 ohm both times. As long as he keeps it at 1 ohm, the amp is great. He's running it on 2 Pierce Audio Products 15" WMD(Weapons of MAss Destruction) subwoofers. Pounds them.Should push the DP's nicely as long as u keep the amp 1 ohm or higher. Hope this helps.
March 14, 200818 yr Author Thanks I appreciate the advice from everyone. This is probably the most informative forum I am a member of. I can't wait to get my hands on two of those. Does anyone have a link to the recommended box dimensions for the 21's? Thanks again for the quality advice.
March 16, 200817 yr I had the SS Pca 2000d and it would not do 0.5ohm i found the Magic Smoke...so i went with Massive p3000.1 it will NOT do rated / co will NOT warranty / it wont do rated ohms either, amp pops every time you try and wang...so i went with Sundown Audio SAZ 1500d x2 strapped and Schwing... banging out 154.6 Spl competition boxx & 152db on a daily boxx and my problems went away... Wanging forever with no problems Dallas TX here ( D/FW ) area...welcome...addvice i had the Massive p3000.1 and its had 4 boards in it in less that a yr not 2ohm stable, su@k@ss customer service all around BAD IDEAi could go on & on & on but you get the point...dont WASTE your MONEY they Su@k@ss
March 16, 200817 yr Author I had the SS Pca 2000d and it would not do 0.5ohm i found the Magic Smoke...so i went with Massive p3000.1 it will NOT do rated / co will NOT warranty / it wont do rated ohms either, amp pops every time you try and wang...so i went with Sundown Audio SAZ 1500d x2 strapped and Schwing... banging out 154.6 Spl competition boxx & 152db on a daily boxx and my problems went away... Wanging forever with no problems Dallas TX here ( D/FW ) area...welcome...addvice i had the Massive p3000.1 and its had 4 boards in it in less that a yr not 2ohm stable, su@k@ss customer service all around BAD IDEAi could go on & on & on but you get the point...dont WASTE your MONEY they Su@k@ssWhat about the earthquake line of amps? I have found this one for of the ph5000's for much less than msrp. What do you guys think? Again thanks for the advice. PH5000W/D1 Number of channels: 1/MonoClass: "D"Max Power Output: 5000 WattsPower 1-Ohm: 1 x 5000 WattsPower 2-Ohm Bridged: 1 x 3000 WattsPower 4-Stereo: 1 x 860 WattsDamping Factor: >800Cross Over Slopes: 24dB/OCTTHD: >0.016SNR: 104dBSpeaker Connections: 8-GaugePower/Ground Connections: 0-GaugeInput Types: Low Level RCA InputsDimensions (HxWxD): 2.375" x 10.125" x 15"MSRP: $1,373.00
