Push?
Do you mean power?
Yes, it will. That is, if the amp actually works.
:D
/sarcasm
That should do a pretty decent job on them.
Dont plan on dropping below 1 ohm on the amp..... A friend of mine has one and has popped it twice when dropping below 1 ohm both times. As long as he keeps it at 1 ohm, the amp is great. He's running it on 2 Pierce Audio Products 15" WMD(Weapons of MAss Destruction) subwoofers. Pounds them.
Should push the DP's nicely as long as u keep the amp 1 ohm or higher. Hope this helps.
:suicide-santa:
Thanks I appreciate the advice from everyone. This is probably the most informative forum I am a member of. I can't wait to get my hands on two of those. Does anyone have a link to the recommended box dimensions for the 21's? Thanks again for the quality advice.
7.5-10 cubic feet per driver will be optimal
I had the SS Pca 2000d and it would not do 0.5ohm
i found the Magic Smoke...
so i went with Massive p3000.1 it will NOT do rated / co will NOT warranty / it wont do rated ohms either, amp pops every time you try and wang...
so i went with Sundown Audio SAZ 1500d x2 strapped and Schwing... banging out 154.6 Spl competition boxx & 152db on a daily boxx :)
and my problems went away... Wanging forever with no problems :slayer:
Dallas TX here ( D/FW ) area...
welcome...
addvice i had the Massive p3000.1 and its had 4 boards in it in less that a yr not 2ohm stable, su@k@ss customer service all around BAD IDEA
i could go on & on & on but you get the point...
dont WASTE your MONEY they Su@k@ss
welcome...
What about the earthquake line of amps? I have found this one for of the ph5000's for much less than msrp. What do you guys think? Again thanks for the advice.
PH5000W/D1
Number of channels: 1/Mono
Class: "D"
Max Power Output: 5000 Watts
Power 1-Ohm: 1 x 5000 Watts
Power 2-Ohm Bridged: 1 x 3000 Watts
Power 4-Stereo: 1 x 860 Watts
Damping Factor: >800
Cross Over Slopes: 24dB/OCT
THD: >0.016
SNR: 104dB
Speaker Connections: 8-Gauge
Power/Ground Connections: 0-Gauge
Input Types: Low Level RCA Inputs
Dimensions (HxWxD): 2.375" x 10.125" x 15"
MSRP: $1,373.00
