Posted March 14, 200817 yr Hey, I was wondering if someone can tell me how to wire up 3 12'' D2's. What ohm will it be pushing at. I currently have a Kicker ZX2500.1 thats pushing 2 Icons. I plan on buying another Icon. My brother & I will be building a fiberglass box for my car. I was wondering if you guys can chime in and give some advices. This is my first box build. My brother done this 3 times. Thanks for your guys time and help.
March 14, 200817 yr Author your options are 0.3333, 1.333, 3, and 12 ohmsDo you think my kicker zx2500.1 Will be stable at 1.333 ohms ? Its stated on the specs that its stable @ 2 ohms.
March 14, 200817 yr with impedance rise, it'll probably be over 2 ohms, but I don't know if the Kicker's protection circuitry is loose enough to allow it
March 14, 200817 yr Author with impedance rise, it'll probably be over 2 ohms, but I don't know if the Kicker's protection circuitry is loose enough to allow iton CA.com people had stated that they got their zx2500.1 to run on 1 ohm. Others stated that it isn't safe. Possibility to be better off upgrading to a Sundown 3k ?
March 14, 200817 yr not safe. Your actual resistance would be 1.0 ohm exactly. Since i've seen impedance rise less than 200% of it's DCR, then it's possible that some notes will be under 2 ohms.
