Posted March 26, 200818 yr for those of you that didnt see in the other thread,i took the first one out. i really wasn't happy with it once i thought about it. this one, already with the false floor, is coming out alot better. the floor is 2 layers thick. the first layer is bolted with 1/2" x 2.5" bolts in the rear, and up front its tite bonded, and screwed to those 2x4's u see under there. the 2x4's themselves are also bolted to the body with the same bolts.none-the-less, its very sturdy, and not gonna budge.the 2nd layer is self explanatory, its to make is 100% level (to cover the bolt heads used to bolt the first layer down)and to clarify, the cuts i made on the rear cross-member, to get those bolts in (still cant believe i did that) will be getting welded shut by my body shop soon. just wanna throw that out there, becuase i know someones gonna comment on the pic that shows those cuts lol...anyways, pics-btw- i havent decided on subs yet. or the exact style of box. im 95% set on doing a ported clam shell, i just gotta see how much space im working with.
March 26, 200818 yr Is that a gigantic subwoofer sized hole in your drivers door? Did you do that? What's it for?
March 26, 200818 yr Author yes im starting over lolthe door panel goes in that hole, idk its just the way the door is.
March 27, 200818 yr Well at least he has another ride to get around in while this build is going in. I wish I could say that. Good luck with this one.
March 27, 200818 yr Good for you man. It takes a level head and discipline to get that far along, realize you took things in the wrong direction, and start over.To make the wall integrate into the trim this time around, and while you have the box out, maybe you should make fiberglass molds of the sides of the car and the roof. That way you can cut perfect trim pieces around the edges of the box.
March 27, 200818 yr Author Good for you man. It takes a level head and discipline to get that far along, realize you took things in the wrong direction, and start over.To make the wall integrate into the trim this time around, and while you have the box out, maybe you should make fiberglass molds of the sides of the car and the roof. That way you can cut perfect trim pieces around the edges of the box.while that would be a great idea for the side panels, for me, its easier (still time consuming) but alot less messy, to just make a card board template, then trace it onto wood cut out the bottom piece of the box. i need to get more Birch.
April 2, 200818 yr Author Actually using real wood for your box this time, eh?last one was birch as well...?lookin good manthanks
April 2, 200818 yr Author cut the odd side pieces out. most of you will be confused, but im gonna get more done tomorow, and you will understand as the pictures progress, as to why its cut like it is.9.5* angledry mock-upsorta what im going to do tomorow. the sides will extend out with the side trim, thats why the side pieces are cut like they are.one of the 18s, i may not even use this, im not sure yetrandom picglued the sides down
April 2, 200818 yr Actually using real wood for your box this time, eh?last one was birch as well...?Ha, you let me call it a box. I do have a question to clarify. You are doing this and you can't drive the Exploder either?
April 2, 200818 yr Author no i dont drive the explorer, but i can still drive this while working on it. i just have stuff inside taken apart right now. still driveable though. just got back from the tint shop, got 15% thrown back on the windshield (got glass replaced a few months ago)
April 2, 200818 yr Author test fitthis may give you a better idea how the sides will be, notice they are flowing the contours of the side panelsput the back on
April 3, 200818 yr Author not bolted down yet.deleted the rear wiper. that plug will be there until i get a rear back up camera. im selling my Nakamichi head unit, as much as i like it, but i want to get a double din screen with Navigation. ill have to relocate the a/c controls, etc
April 4, 200818 yr Author not much done today...by the time i got home from work it was 5ish, then had to go somewhere at 8 so....ill do this to the other side tomorow probably.does it sort of make more sense now as to why the sides are like that?just to throw this out there, i AM fiberglassing the ENTIRE interior of the box for added strength, and to ensure is 110% air tight.
April 12, 200818 yr Author random picsdoor is double 5, windshield is 15, the glare strip at the top is 5% over the 15%.
April 12, 200818 yr Author probably not going to do anything else on the box tonight. tomorow i wanna try and finish the sides and the top.i changed the oil in the car today as well.friend of mine hahahhah
April 24, 200818 yr Author box = in for good.glued/screwed it down to the false floor today.the side panels are just sitting there, i havent put them in yet. gonna get the top piece cut before i screw those 2 window panels in. theres padding on the back as well, where it hit the window a bit.had a whole sheet of birch, and all i have left is the top/front/port, which wont be a whole sheet, so instead of 2x4s, i added a 2nd layer of 3/4" birch to the back, it made it very solid.had to 2 piece ithell, i like how the back is looking better than the front lol.also, as far as all the 90 degree angles inside the box go....im going to round them all before i fiberglass the entire interior of the box, but the box will be complete before i do so. also, i just want to test the box without glass/rounding the edges, and see how it sounds, and go from there.
April 25, 200818 yr Author go big, or go home1 of 2 18" recone/basketnext to 12" baskettemplate for the back trim panel. gotta go get some 1/4" birch tomorow, 11 bux for a 4x8 sheet, and it weighs NOTHING lol.
