Posted March 28, 200818 yr I recently burnt one of the leads on my sub. is soldering the wires back together the best way to fix it? if not what is the best way?
March 28, 200818 yr burnt? Considering the variability of what you could be describing a bit more detail would be helpful.
March 28, 200818 yr if you can get a new lead that would be the place Id start at if not you gotta recone it if you were to just reattatch it chances are its gonna be too short and snap again
March 28, 200818 yr That would be broke... and cause? Likely overexursion.Need a new tinsel lead, solder won't hold it together well.
