Posted April 1, 200817 yr I am in need of an amp. I will be getting an RE XXX 15 and I want to push it with about 1500 watts. What do you guys suggest for an amp?I was considering:Hifonics Brutus 2k wattRockFord 20001bdHowever, I don't no much about amps and brands. Suggestions Welcome. Thanks.
April 1, 200817 yr Most people are going to say to stay away from Hifonics. That RF amp would do just fine, wire the 15 in parallel to get you down to 1 ohm. You could also go with a Sundown 1500, if you can get the sub in 1ohm I would personally suggest a kicker zx1500.1
