Posted April 13, 200818 yr anyone know of any good 6inch subs around? I am looking for good sound quality and pretty good low end as well.
April 13, 200818 yr Tang Band and JL are about the only two that come to mind right away.May I ask what the application is? You could always beef up the front stage with large midbasses and remove the need for separate subs altogether
April 13, 200818 yr A true "subwoofer" by terms of which frequencies it's responsible for reproducing gets fairly inefficient when you go that small.Midbass drivers are a different story and depending on how space available, you can sometimes fit larger midbass drivers than subs because the lack of a massive motor structure or deep mounting depth commonly found on subs.
April 13, 200818 yr Author Single cab Toyota Tacoma. Already got 2 6inch bazooka's but wanted to get something better. There is almost no room at all to put a box back there either. All kind of crap welded to the back of the cab-no space.
April 14, 200818 yr Mypre Audio makes a 6.5" sub.made a 6.5. i believe they are no longer in business. unless my searchign skills jsut flat suck.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
April 14, 200818 yr Mpyre went down with Adire. It is really too bad, they had some promising products. I happen to own one of the Mpyre 65x's and have 2 more that I am getting for a friend. I tell you, I love that lil sub.
