Posted April 16, 200817 yr I am planning a box design in which I am using two 3" aero ports. The ports are supposed to be 7 inches long. My question is when using aero ports does the actual tube have to be seven inches or does the entire port assembly (flares included) need to be 7 inches? Edited April 16, 200817 yr by basshead08
April 17, 200817 yr if your design is suppose to have the ports 7" long, then the entire assembly needs to be 7" long.So, if the flare is already 4", for example, then you only need 3" of tubing.
April 17, 200817 yr if your design is suppose to have the ports 7" long, then the entire assembly needs to be 7" long.So, if the flare is already 4", for example, then you only need 3" of tubing.wrong...the entire port needs to be (1) inch longer than 7 inches...im looking at the formula
April 20, 200817 yr Author if your design is suppose to have the ports 7" long, then the entire assembly needs to be 7" long.So, if the flare is already 4", for example, then you only need 3" of tubing.wrong...the entire port needs to be (1) inch longer than 7 inches...im looking at the formulawhere is that formula located? Could you post a link please?
