April 10, 200818 yr Just to clarify, the power,ground, and remote wires are hooked up normal on strapped amps, nothing different, and the gain/freq/filter settings on slave amp do not matter, becuase it gets all of that information from the master amp via the rca cables...
April 10, 200818 yr has someone seriously sent an amp back in the cosmetic box with out an outer box?
April 10, 200818 yr Author has someone seriously sent an amp back in the cosmetic box with out an outer box?Yes, it has happened fairly often.
