Posted April 22, 200817 yr ok so i found these in my garage and i have no idea what the hell they are could someone help me out i think they are like crossovers or something but i have no idea it says infinity reference on it
April 22, 200817 yr Author do you know how they get wired up??? sorry im pretty much a newb when it comes to this chit
April 22, 200817 yr Each passive crossover set is designed to work for a specific pair of speakers because diffrent speakers need diffrent crossover frequencies.You can use it with other speakers, but they will not perform as good as possible.I believe "IN" is pretty basic. It's the input.You connect the mid-bass to the "WF" terminal.You connect the tweeter to the "TW" terminal. the -3dB terminal is used for the tweeter. You connect the positive wire either to the TW+ terminal or to the -3dB terminal. The latter terminal is used to provide a lower level for the tweeter in case it's too loud for your tastes.
April 22, 200817 yr Author ok thanks i plan on installing a set of infinitys into my cvic sedan. i have been trying to think about how to run the set up that i want but i just cant figure it out... maybe one of you guys can help me out here. is what i what to do is have a set a tweeters in the A pillars and 6 1/2's in all 4 doors and in the trunk because that is the only thing that fits stock. but i cant figure out how to wire the speakers to the rear doors with out it sounding distorted. by the way im really wanting to this off of a stock honda head unit
April 22, 200817 yr ok thanks i plan on installing a set of infinitys into my cvic sedan. i have been trying to think about how to run the set up that i want but i just cant figure it out... maybe one of you guys can help me out here. is what i what to do is have a set a tweeters in the A pillars and 6 1/2's in all 4 doors and in the trunk because that is the only thing that fits stock. but i cant figure out how to wire the speakers to the rear doors with out it sounding distorted. by the way im really wanting to this off of a stock honda head unit pop the cover off.. and you will see the tw sw an the in... althought u will get a better sound IMO if you run it on an amp..
