Posted April 27, 200818 yr I'm going to be buying (4) 6.5 inch midbass drivers and I'm looking at either the Kicker SS6.5s or the Mach5 Audio 6.5 midbass. They will be actively crossed at 60hz up @24db and 200hz down @12db. They will be getting 75watts rms each and run free-air in the stock door locations of my '04 Dodge Durango. Any thoughts...other suggestions. Either way I go it will only cost me about $150 and that's the range I would like to stay around.
April 28, 200818 yr Author That sounds like a plan. What midranges are you using?I have Diamond Audio M6 4.5 mids and M&K(Vifa built I think) soft dome tweets...sounds really smooth. My sub is a TC Sounds TC3k 15. Right now I'm using Diamond Audio M6 6.5 mids in the doors for midbass with the same crossover points I plan to use for the midbasses...they sound good but don't handle the power all that well. That's why I'm looking for more midbass oriented drivers.
