April 30, 200817 yr please post up the T/s & displacement for your sub !!!ill run a new plot for ya sealed & ported
May 1, 200817 yr Author heres what i found about the sub the new ones because the older version does not come 15"Mounting Depth - 13.5"Mounting Hole Diameter - 14.5"Overall Diameter - 16"Bolt Hole Circle - 15.25"Motor Width - 10.5"Motor Depth - 5"Basket Depth - 8.5"Displacement - 0.27 cu. ft.Weight - 76 lbs.15"Electrical Q Value -Qes: 0.58Mechanical Q Value -Qms: 3.62Total Speaker Q Value -Qts: 0.501Free Air Resonance -Fs: 19.10 HzEquivalent Compliance -Vas: 207.0 litersOne-Way, Linear Excursion -Xmax: 54 mmEfficiency -SPL 1W/1m: 85.81 dB SPLEffective Piston Area -Sd: 810 cm^2DC Resistance -Re: 4.2 ohmNominal Impedance -Znom: Dual 2 ohmThermal Power Handling -Pe: 2000 WForce Factor -Bl: 18.16Mounting Depth - 13.5"Mounting Hole Diameter - 14.5"Overall Diameter - 16"Bolt Hole Circle - 15.25"Motor Width - 10.5"Motor Depth - 5"Basket Depth - 8.5"Displacement - 0.27 cu. ft.Weight - 76 lbs.15"Sealed:ported:18"Sealed:ported:Compact0.851.7@35HzCompact1.63.2@35HzCompact3.36.0@35HzOptimal1.12.2@34HzOptimal2.14.0@33Hbut this is from the new oner i dont know if they are the same man i bought them used to a distribuitor in puerto ricoheres the link http://reaudio.com/specs.html#sp_xxx Edited May 1, 200817 yr by juanl
