Title says it all right?
I've pre-ordered the subwoofers, I will get them near the end of may/ early june.
This is the stratus:
I will be tearing out the old baffle, and the front.
Making some kind of base, battery rack, and amp rack in the trunk.
Clamshell will go behind the seats, then I will seal the trunk off, stuff it with polyfill.
I bought E8's (sundown)
The final specs will look like this:
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Sealed Box:
0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
They should be black instead of chrome.
This will be fun! :veryhapp:
these will be powered by 1 or two sundown 3000d's
  • Replies 71
  • Views 10k
Actually it doesn't, the title confuses the crap out of me :P
cutting glass smells like pine.
That back of that truck, looks exactly like my cousin's A/C truck. Junk and chit everywhere just thrown in the back.
wow
thats gong to be loud
80
Alright, got a lot more out, once I get everything I need out I can start cutting the metal that is in the way.
Then on to sealing the trunk off from the cabin, in prep for the box/baffle.
Edited by Rawr-dq
what did u have in there before?
what the hell is a Bandpass IB Clamshell box?
Are you undecided which you're going with or just retarded?
:P
Clamshell designs at like bandpass boxes, I didn't have the room for a congruent baffle.
However, this enclosure will not be sealed, it'll be open to the trunk/area outside of the cabin.
So basically your calling it bandpass b/c it is firing into the "sealed cabin"... The way it looks you are just doing a clamshell (trunk baffle not even infinite baffle)
Well no, because it fires inside the mouth of the baffle. The opening has less surface area than the speakers.
and if I open the trunk it'd be a true IB...but I will be stuffing it with polyfill to help dissipate those back waves.
i'm not worried about what it's called, it's called my setup, and I was just looking for a title to entertain you guys.
Edited by Rawr-dq
I probably would have went with. " A build that you have never seen before" lol.
should be impressive none the less
keep the pics coming
