Got my amp and sub hooked up, started bumping some music then it cut off. I went back to check out what was going and and saw that a razor blade had fallen across the speaker terminals on the amp. Now the amp wont power up.
Never mind when the bass hit it diconnected the remote on wire at the same time the blade fell so lucky me.
it could have ejected the wire too if it was not tight enough!
A long time ago, before i knew what i was doing, i had a class d amp go into protection due to the power slipping out of the terminal...
When i checked to see what happened because this happened while driving, this is what i saw-
Burn marks all around the power terminal which means the wire had arced all around on it's way out.
But the most shocking thing is 2 of 3 fuses in the amp got shot out of the amp! I'll never forget that.
