Posted May 6, 200817 yr Help SPL dinamics Est-3000 failure , i try circuit diagram plate DWM360NHV_v30 .clones amplifier model:. American Bass VFL 200.1. E-Audio 3000D. Ground Zero GZPA 1.5000SPL. Hifonics Goliath GX3000D
May 6, 200817 yr Where are you from ? I have worked on the AB 200.1 and I may be interested in buying the SPL dynamics if you want to sell it...
May 7, 200817 yr Author Help SPL dinamics Est-3000 failure , i try circuit diagram plate DWM360NHV_v30 .I found component failures is the key for'm trying to make repairs? I have already changed the final sull'ali IRFN064n is the final audio IRFP360LC I lack to repair the module pilot of IRFP360LClink amp:http://ampguts.realmofexcursion.com/SPL_Dynamics_EXT-3000D/Linking photos module to be repaired :http://i280.photobucket.com/albums/k...05-08_2202.jpgclones amplifier model:. American Bass VFL 200.1. E-Audio 3000D. Ground Zero GZPA 1.5000SPL. Hifonics Goliath GX3000DI need to know value components U1, U2, CL1, Cl4, R9, R36, U3, U4Scusate se non scrivo bene in inglese scrivo dall'Italia
May 7, 200817 yr Any chance you speak romanian ? It would be a lot easier to help if we can understand each other.
