Posted May 8, 200817 yr so i got:optima yellowtop under the hoodkinetik hc2400 on the backiraggi 240/165 amp alternatorit was running fine for about a week since i installed it,my voltages were:14.2@idle, 13.4v w/ engine offthis morning it was running fine tooso when i was leaving this afternoon, i noticed the battery gauge was pretty lowi checked the voltage and it was only 12.7 while the car is idling and system is off so i turned my car off and checked the voltage, it was 12.8so i disconnected my powerwire that runs to the back battery and the ampsafter about half hour drivingi checked the voltage, while idle it was 12.3when it was off it was 12.5what do you guys think? did my alternator died?i checked all the wire connections and it seems that its good
May 8, 200817 yr so i got:optima yellowtop under the hoodkinetik hc2400 on the backiraggi 240/165 amp alternatorit was running fine for about a week since i installed it,my voltages were:14.2@idle, 13.4v w/ engine offthis morning it was running fine tooso when i was leaving this afternoon, i noticed the battery gauge was pretty lowi checked the voltage and it was only 12.7 while the car is idling and system is off so i turned my car off and checked the voltage, it was 12.8so i disconnected my powerwire that runs to the back battery and the ampsafter about half hour drivingi checked the voltage, while idle it was 12.3when it was off it was 12.5what do you guys think? did my alternator died?i checked all the wire connections and it seems that its goodwhere are you checking the voltage from?
May 8, 200817 yr so i got:optima yellowtop under the hoodkinetik hc2400 on the backiraggi 240/165 amp alternatorit was running fine for about a week since i installed it,my voltages were:14.2@idle, 13.4v w/ engine offthis morning it was running fine tooso when i was leaving this afternoon, i noticed the battery gauge was pretty lowi checked the voltage and it was only 12.7 while the car is idling and system is off so i turned my car off and checked the voltage, it was 12.8so i disconnected my powerwire that runs to the back battery and the ampsafter about half hour drivingi checked the voltage, while idle it was 12.3when it was off it was 12.5what do you guys think? did my alternator died?i checked all the wire connections and it seems that its goodcheck all the negative wires again if thats not it I would bring your vehicle to a mechanic and have him check out your alternator.
May 8, 200817 yr vato zone or your local part house can check it for free...... imo 13.4 is very good for being off.. and 14.2 is right fo running.... it could be alot of things... check the amp u first... to me it sounds like the voltage regulater or the dioeds.. its still charging just not correctly
May 8, 200817 yr if u take it to auto zone, do NOT let them disconnect your power wire to your batt from alt while car is running.OH and one more thing, have you ever checked the voltage your alt puts out when above idle?Kinetik's do NOT like anything out of the range of 14.0-14.4v Edited May 8, 200817 yr by shizzzon
May 8, 200817 yr you should be using powermasters with that alt anyway i talked to dominick on the phone and he said that he has nothing but problems with the kinetik batts and his alts he told me to use powermaster wile running his alts that could be your prob
May 8, 200817 yr you should be using powermasters with that alt anyway i talked to dominick on the phone and he said that he has nothing but problems with the kinetik batts and his alts he told me to use powermaster wile running his alts that could be your prob if your gonna shop at powermaster Just tell Dom to take his damn alt back and get a quality one from Powermaster
May 8, 200817 yr jeje well it happen to me one time te fuse tht was for the external regualtor blow and it wasnt charging because it dont have power
May 8, 200817 yr you should be using powermasters with that alt anyway i talked to dominick on the phone and he said that he has nothing but problems with the kinetik batts and his alts he told me to use powermaster wile running his alts that could be your prob Last time I checked, powermasters and kinetics charged the same way. Add current.
May 9, 200817 yr I know quite a few people who have had nothing but trouble from Iraggi Alts. I would assume its toast.
